[OSRS-PROJ] EPSG: invalid projections?
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 24 06:28:01 PDT 2003
Jan-Oliver Wagner wrote:
> Hi,
> got no feedback on this issue. The epsg file in CVS is still the same
> as in proj 4.4.7.
> For Thuban I will remove them.
> On Fri, Oct 10, 2003 at 06:28:12PM +0200, Jan-Oliver Wagner wrote:
>>I've implemented a converter for the epsg file as delivered with
>>proj to a Thuban .proj file.
>>When loaded into Thuban there is an automatic test for each
>>projection and 4 of the 2480
>>seem to be incorrect. These are the error messages:
>>Error in projection "CH1903+ / LV95": lat_0 = 0 or 90 or alpha = 90
>>Error in projection "Bern 1898 (Bern) / LV03C": lat_0 = 0 or 90 or alpha = 90
>>Error in projection "CH1903 / LV03": lat_0 = 0 or 90 or alpha = 90
>>Error in projection "HD72 / EOV": lat_0 = 0 or 90 or alpha = 90
>>I've used proj 4.4.7.
Jan-Oliver,
I suggest you file this in bugzilla as a bug. I would guess I am
incorrectly translating these coordinate systems but it will take some
investigation to see what is going wrong, and what should be done.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
