SV: [OSRS-PROJ] ED50 Denmark
Torben Bach
torben.bach at geo.au.dk
Fri Oct 24 01:55:48 PDT 2003
Hi Paul
THANKS !!! I was using proj4 directly, not the cs2cs program. The
ellipsoid used is actually WGS84, but entering this into your golden
command line fixes my problem. If your currious heres what I get from my
comparison:
In-put coordinate: 10.138618 56.342032
Outputs:
MapInfo : 570466.57247057 6244935.6590597 (According to MapInfo they
have an error)
KMS Trans: 570464.297 6244936.971 (Official Danish program
Thingy :-) )
cs2cs : 570464.18 6244937.01 (Pauls Golden Line)
PERFECT !
Thanks a lot !!
Best regards,
-Torben
The commandline used:
cs2cs +proj=latlong +ellps=WGS84 +towgs84=0,0,0 +to +proj=utm +zone=32
+ellps=intl +towgs84=-81.1,-89.4,-115.8,0.485,0.024,0.413,-0.54
-----Oprindelig meddelelse-----
Fra: Paul Kelly [mailto:paul-grass at stjohnspoint.co.uk]
Sendt: 24 October 2003 09:59
Til: Torben Bach
Emne: Re: [OSRS-PROJ] ED50 Denmark
On Thu, 23 Oct 2003, Torben Bach wrote:
> Hi
> Completely new to the subject I have been roaming the internet trying
> to find a "golden" command line to proj4 for converting lat-lon
> coordinates to DANISH ED50 UTM zone 32N. Apparently the internal ED50
> is not the same as the Danish (or german or french...) ED50 - im am
> confused - does anybody know the "golden" command line I so badly long
> for ?
You don't say which ellipsoid your latitude/longitude co-ordinates refer
to. Seeing you mention EUREF89 in the next paragraph I will assume it is
the GRS80... according to
http://crs.ifag.de/country_select.php?country=DK
then your command line with datum transformation parameters would be
something a bit like
cs2cs +proj=latlong +ellps=GRS80 +towgs84=0,0,0 +to +proj=utm +zone=32 \
(Actually these parameters are in GRASS if you go to set up a Denmark
location.)
Does this work?
> Another question - how accurate is the ouput from Proj4 ? I have
> compared results converting to EUREF89 with output from programs from
> the national Ministry of the Environment (KMS at www.kms.dk) handling
> this stuf and MapInfo, and they gave the same results within a meter
> or so. But using ED50 and Proj4 gave coordinates lying hundreds of
> meters from MapInfo and "official" KMS results (this was how I
> discoverd I needed the "golden" command line).
As hinted above you don't say which ellipsoid your lat-long co-ordinates
are on but presumably it is not ED50 and therefore you need datum
transformation parameters.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
