[OSRS-PROJ] Changes in EPSG codes?
Jan-Oliver Wagner
jan at intevation.de
Fri Oct 24 01:30:59 PDT 2003
I am troubled with the EPSG codes as in different versions of proj:
In Version 4.4.5 there is a code 31493 which is not there anymore
in Version 4.4.7 (where a new code is used for the same projection:
31467).
First of all I wonder, whether this is a fix in proj or a change in
EPSG?
The trouble I have is that a UMN MapServer WMS application running with
proj 4.4.5 can not be accessed from a WMS Client that uses proj 4.4.7.
Is this a common problem? Is there a common solution?
Any comment is appreciated.
Best
Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
