[OSRS-PROJ] Changes in EPSG codes?
Fri Oct 24 06:26:39 PDT 2003
Jan-Oliver Wagner wrote:
> Hi,
> I am troubled with the EPSG codes as in different versions of proj:
> In Version 4.4.5 there is a code 31493 which is not there anymore
> in Version 4.4.7 (where a new code is used for the same projection:
> 31467).
> First of all I wonder, whether this is a fix in proj or a change in
> EPSG?
> The trouble I have is that a UMN MapServer WMS application running with
> proj 4.4.5 can not be accessed from a WMS Client that uses proj 4.4.7.
> Is this a common problem? Is there a common solution?
Jan-Oliver,
This reflects a change in the EPSG database.  In theory I think it would
be possible to try and do something to merge in deleted codes from old
databases to retain better backward compatibility but I haven't tried to
do that.
I know this sort of thing can be quite annoying, and I don't know why
EPSG actually removes superceeded coordinate systems.  I had previously
thought this was not their policy.
The "changes" table in the EPSG db has a corresponding record that
reads:
2000.101,2000-03-07 00:00:00,2000-03-07 00:00:00,Jean-Patrick Girbig; IHS Energy,Amend Germany
CS,HorizCS,31491-95,Changes name from DHDN / Germany zone x to DHDN / Gauss zone x.,Replaced Germany projCS 31491-95
with 31461-65 respectively.  Deleted proj 18101-05.
What I would kind of like to have is a n "epsg_plus" table with all current
EPSG definitions, plus ones deleted from older versions, plus ESRI custom
codes.  This could then be used by folks wanting to maintain a maximimally
fleshed out set of definitions for MapServer and similar applications.
However, building such a thing is not a trivial effort.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
