[Proj] Error code for PJD_ERR_GEOCENTRIC and pj_strerrno()
proj-admin at remotesensing.org proj-admin at remotesensing.org
Thu Apr 15 06:11:34 PDT 2004
proj-admin at remotesensing.org wrote:
> Hi all,
> According to the documentation, errors detected by libproj itself should
> always
> have negative numbers, whereas errors in system libraries have positive.
> I recently got error number 100, which turned out to be the following error,
> defined in projects.h:
>     /* datum system errors */
>     #define PJD_ERR_GEOCENTRIC 100
> Is there a reason this error doesn't follow the strategy of the other
> errors,
> and that it isn't "known" by pj_strerrno().
Thomas,
I have no idea why I did it this way.  I have corrected this in CVS.
Best regards,
