[OSRS-PROJ] proj4 parameter question regarding UTM
pw p.willis at telus.net
Fri Feb 6 15:31:34 PST 2004
Hello,
I have been attempting to use proj to project latlons to utm.
In testing on the command line I get incorrect utm coordinates
based on the latlons that I am providing.
Question A.) (in case of a scaling problem)
What scale does does proj project latlons to.
eg. UTM feet, UTM meters
Question B.) (in case my parameters are wrong)
When using proj on the command line I am entering the following:
proj +proj=utm +ellps=WGS84 +zone=10
Is that correct?
Here is what I get at the command prompt:
I enter my lons and lats at the prompt.
-143.228         55.380
proj returns incorrect values
-771781.86            6325041.42
Actual correct utm values for this coord WGS84 utm zone 10 (north):
358851.385 east                 6139389.448 north
Thanks for any help,
Peter
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
