[OSRS-PROJ] Rectified Skew Orthomorphic...EPSG
Gerald Evenden
gerald.evenden at verizon.net
Mon Feb 9 17:59:14 PST 2004
First the script of Mr. Smart's test data:
#!/bin/bash
echo "test data from John Smart (john.smart at caris.com)"
prog="../lproj"
parms="+proj=omerc +lat_0=4d00\'00.000N +lonc=115d00\'00.000E \
+alpha=53d18'56.9537 +gamma_c=53d7'48.3685 \
+k_0=0.999840 \
+y_0=5000000 +x_0=2000000 \
+a=6377298.560 +b=6356097.554 "
cat <<EOF >tempa
5d00'39.3328N 115d02'46.4797E 2595244.677 5554640.242
4d51'17.2684N 114d55'50.4365E 2582484.393 5537337.229
4d00'00.000N 115d00'00.000E 2590476.87 5442857.66
2d25'30.000N 111d08'00.000E 2161074.28 5268121.72
2d30'00.000N 111d16'00.000E 2175900.30 5276416.44
2d25'30.000N 111d16'00.000E 2175901.71 5268123.87
EOF
$prog -f '%.3f' -r $parms tempa >tempb
$prog -o -r $parms tempa | $prog -i -I -W4 $parms >tempc
echo "projection arguments:"; echo $parms
echo "original data"; cat tempa
echo "omerc forward projection"; cat tempb
echo "omerc inverse projection"; cat tempc
/bin/rm tempa tempb tempc
Note that this version still requires both alpha and gamma_c even
though they are interrelated---in this particular case.
Results from above script:
+alpha=53d18'56.9537 +gamma_c=53d7'48.3685 +k_0=0.999840 +y_0=5000000
+x_0=2000000 +a=6377298.560 +b=6356097.554
original data
2595244.682 5554640.245 2595244.677 5554640.242
2582484.398 5537337.232 2582484.393 5537337.229
2590476.876 5442857.657 2590476.87 5442857.66
2161074.283 5268121.723 2161074.28 5268121.72
2175900.304 5276416.437 2175900.30 5276416.44
2175901.717 5268123.865 2175901.71 5268123.87
115d02'46.4797"E 5d00'39.3328"N
114d55'50.4365"E 4d51'17.2684"N
115d00'00.0000"E 4d00'00.0000"N
111d08'00.0000"E 2d25'30.0000"N
111d16'00.0000"E 2d30'00.0000"N
111d16'00.0000"E 2d25'30.0000"N
Comparison is fairly good to the centimeter.
Who is correct to the millimeter?
Comments appreciated and many thanks to Mr. Smart.
On Feb 9, 2004, at 6:24 PM, John Smart wrote:
> Gerald et al
> These are some parameters and test points which have been used by
> CARIS for
> Borneo RSO. As far as I can recall, these parameters were tested
> against
> some local clients' survey calcution programs.
> Scaling lat 4-00-00.000N
> Central meridian 115-00-00.000E
> Skew Azimuth 53-07-48.3680
> Scaling factor 0.999840
> False North 5000000
> False East 2000000
> Ellipsoid a, b: 6377298.560 6356097.554
> geographic:
> 5-00-39.3328N 115-02-46.4797E
> 4-51-17.2684N 114-55-50.4365E
> 4-00-00.000N 115-00-00.000E
> 2-25-30.000N 111-08-00.000E
> 2-30-00.000N 111-16-00.000E
> 2-25-30.000N 111-16-00.000E
> grid:
> If I can be of further assistance, let me know. Incidentally, I have
> the
> same kind of thing for Malayan RSO.
> John Smart - Senior GIS Analyst
> Marine Division
> CARIS www.caris.com
> Tel: +1-506-458-8533 Fax: +1-506-459-3849
> CARIS has expanded to new office facilities. Our new mailing address
> is:
> 115 Waggoners Lane, Fredericton, New Brunswick, E3B 2L4, Canada.
<snip>
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
