[OSRS-PROJ] Rectified Skew Orthomorphic...EPSG
John Smart
john.smart at caris.com
Mon Feb 9 15:24:59 PST 2004
Gerald et al
These are some parameters and test points which have been used by CARIS for
Borneo RSO. As far as I can recall, these parameters were tested against
some local clients' survey calcution programs.
Scaling lat 4-00-00.000N
Central meridian 115-00-00.000E
Skew Azimuth 53-07-48.3680
Scaling factor 0.999840
False North 5000000
False East 2000000
Ellipsoid a, b: 6377298.560 6356097.554
geographic:
5-00-39.3328N 115-02-46.4797E
4-51-17.2684N 114-55-50.4365E
4-00-00.000N 115-00-00.000E
2-25-30.000N 111-08-00.000E
2-30-00.000N 111-16-00.000E
2-25-30.000N 111-16-00.000E
grid:
2595244.677 5554640.242
2582484.393 5537337.229
2590476.87 5442857.66
2161074.28 5268121.72
2175900.30 5276416.44
2175901.71 5268123.87
If I can be of further assistance, let me know. Incidentally, I have the
same kind of thing for Malayan RSO.
John Smart - Senior GIS Analyst
Marine Division
CARIS www.caris.com
Tel: +1-506-458-8533 Fax: +1-506-459-3849
CARIS has expanded to new office facilities. Our new mailing address is:
115 Waggoners Lane, Fredericton, New Brunswick, E3B 2L4, Canada.
----- Original Message -----
From: "Gerald Evenden" <gerald.evenden at verizon.net>
To: <osrs-proj at remotesensing.org>
Sent: Saturday, February 07, 2004 2:30 PM
Subject: Re: [OSRS-PROJ] Rectified Skew Orthomorphic...EPSG
> An additional insight on the Hotine.
> Axis rotation point may also vary. In Alaska and Borneo the point of
> axis rotation is at the map's central point (lonc, phi_0). In the case
> of the Malayan system, rotation looks to be at the aposphere
> equator and lambda_0.
> Thus it appears that I need to reestablish the +no_uoff option of
> the old PJ_omerc---Malaya was apparently the reason it was there.
> I believe I will change the name of the option because the uoff
> part is not that clear without reading the math.
> I presume nobody in this group is using it nor even aware of it
> presence. :-)
> _____________________________________
> Jerry and the low riders: Daisy Mae and Joshua
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
