[OSRS-PROJ] proj4 parameter question regarding UTM
Hersman, William
willy.hersman at conocophillips.com
Fri Feb 6 15:55:46 PST 2004
That lat, long is in zone 7. You are trying to get a psuedo-zone value, 3 zones away.
-----Original Message-----
[mailto:owner-osrs-proj at remotesensing.org]On Behalf Of pw
Sent: Friday, February 06, 2004 2:32 PM
To: osrs-proj at remotesensing.org
Subject: [OSRS-PROJ] proj4 parameter question regarding UTM
Hello,
I have been attempting to use proj to project latlons to utm.
In testing on the command line I get incorrect utm coordinates
based on the latlons that I am providing.
Question A.) (in case of a scaling problem)
What scale does does proj project latlons to.
eg. UTM feet, UTM meters
Question B.) (in case my parameters are wrong)
When using proj on the command line I am entering the following:
proj +proj=utm +ellps=WGS84 +zone=10
Is that correct?
Here is what I get at the command prompt:
I enter my lons and lats at the prompt.
-143.228 55.380
proj returns incorrect values
-771781.86 6325041.42
Actual correct utm values for this coord WGS84 utm zone 10 (north):
358851.385 east 6139389.448 north
Thanks for any help,
Peter
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
