[OSRS-PROJ] proj4 parameter question regarding UTM
pw
p.willis at telus.net
Fri Feb 6 16:14:22 PST 2004
Hello,
In the case where my map crosses several UTM boundaries
and my central meridian is in zone 10, how can I project
the edge data, which as you have noted is in zone 7, into zone 10?
Should I use tmerc instead?
Peter
> Peter -
> Those are NOT the correct values for those coordinates projected in UTM.
> Your longitude of -143 degrees isn't even close to zone 10 - it's in UTM
> zone 7. The Northing and Easting you report seem approximately correct
> for the zone 7 coordinates of that point, so you should simply change
> your proj command line to specify zone 7.
> - Ed
> Ed McNierney
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
