[SPAM] - Re: [OSRS-PROJ] Error projecting Geographic to UPS - Email found in subject
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 7 13:08:14 PST 2004
Charles D. Van Dusen wrote:
> Hi Frank
> Thanks for the reply.
> This from the proj manual:
> Universal Polar Stereographic (UPS) Projection
> Usage and options: +proj=ups +south
> The ups projection is a special case polar aspect of the Stereographic
> projection
> designed to cover the regions where
84 N or
80 S. The internal
> Stereographic
> parameters are fixed at k0 = 0.994, 0 = 0, x0 = y0 = 2, 000, 000m, and
0 is either 90 N when +south is not specified or 90 S when +south is
> specified.
> Elliptical parameters must be used (either proj default or entered as
> option). Also
> see the Universal Transverse Mercator (utm) projection (p. 12).
> So, I presumed that using the option -o"proj=ups" would suffice.
Charlie,
Doh! You are right. I should have looked before speaking.
I tried "proj +proj=ups" at the commandline and it worked fine, but
"proj +proj=ups +no_defs" failed since there was no ellipse definition.
Try something like "+proj=ups +ellps=WGS84" as your definition instead.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
