[SPAM] - Re: [SPAM] - Re: [OSRS-PROJ] Error projecting Geographic to UPS - Email found in subject - Email found in subject
Charles D. Van Dusen
charlie at im-design.net
Wed Jan 7 14:04:22 PST 2004
Thanks Frank
Worked great!
-----Original Message-----
[mailto:owner-osrs-proj at remotesensing.org] On Behalf Of Frank Warmerdam
Sent: Wednesday, January 07, 2004 4:08 PM
To: osrs-proj at remotesensing.org
Subject: [SPAM] - Re: [SPAM] - Re: [OSRS-PROJ] Error projecting
Charles D. Van Dusen wrote:
> Hi Frank
> Thanks for the reply.
> This from the proj manual:
> Universal Polar Stereographic (UPS) Projection Usage and options:
> +proj=ups +south The ups projection is a special case polar aspect of
> the Stereographic projection designed to cover the regions where
> 84 N or
80 S. The internal Stereographic parameters are fixed at
> k0 = 0.994, 0 = 0, x0 = y0 = 2, 000, 000m, and
0 is either 90 N
> when +south is not specified or 90 S when +south is specified.
> Elliptical parameters must be used (either proj default or entered as
> option). Also see the Universal Transverse Mercator (utm) projection
> (p. 12).
> So, I presumed that using the option -o"proj=ups" would suffice.
Charlie,
Doh! You are right. I should have looked before speaking.
I tried "proj +proj=ups" at the commandline and it worked fine, but
"proj +proj=ups +no_defs" failed since there was no ellipse definition.
Try something like "+proj=ups +ellps=WGS84" as your definition instead.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
