[OSRS-PROJ] Rectified Skew Orthomorphic...
Carl Godkin
carl at dgi.com
Thu Jan 15 11:50:12 PST 2004
> Carl,
> To the best of my knowledge we didn't really support RSO before.
>> If not, I would be happy to contribute either my PJ_rso.c
>> or at least explain on this list what I had to change.
>> (I based my changes on the mathematics described by the
>> EPSG.)
> Would it make sense to have this "gamma" value as an argument to
> omerc that defaults to whatever it used to be, but that could
> be set to produce the RSO projection?
I think so. There are only two very slight differences.
> In any event, if you provide the PJ_rso.c I would be willing to
> incorporate it into PROJ.4, but it would be best if Gerald first
> decided how it should be handled in libproj4. I would want to
> ensure that it is done the same way in PROJ, so that when I ditch
> all my projection code and plug in libproj4 as the backend there won't
> be an incompatible change in how RSO is handled for users.
> Submitting the suggested change in Bugzilla would be a good start.
Ok, I'll do this soon and explain the differences.
Thanks,
carl
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
