[OSRS-PROJ] SOM-A
Gerald Evenden
gerald.evenden at verizon.net
Fri Jan 23 17:18:36 PST 2004
Oh boy! The only amount that I have looked at it was many years ago and
that was only to check that it could replicate JPS' test numbers. I
will give it
a quick look and see if I understand any of it.
At the moment I am about half way through omerc and trying to figure out
a computation in gctp/prpj that is not documented anywhere. BTW, EPSG
is
*not* a very good code source. What is in there is basically JSP'
workup
but lacks some critical details. It is not from Hotine.
On Jan 23, 2004, at 4:45 PM, Frank Warmerdam wrote:
> Gerald Evenden wrote:
>> Space obl.. merc is in PROJ.4, basically a copy of gctp.
>> +proj=lsat
> Gerald,
> It's embarrassing what I don't know sometimes. I see it is driven by
> the lsat (presumably land sat number) and path values much like the old
> GCTP formulations I have seen. Would it be hard to update the code to
> support the explicit parameters JPL is suggesting?
> 3 Inclination of orbit ascending node. (angular units)
> 4 Longitude of ascending orbit at equator. (angular units)
> 7 Period of satellite revolution. (time in minutes)
> 8 Satellite ratio. This controls the start and end points of the
> map on
> the earth surface.
> My presumption is that these are being computed internally from the
> landsat
> number and path ... is that right? Are these JPL guys going at the
> problem
> in a good way to reduce the projection to it's underlying parameters
> or is
> it just going to make it a huge hassle for people to enter?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
More information about the Proj
