[OSRS-PROJ] Rectified Skew Orthomorphic...
Gerald Evenden
gerald.evenden at verizon.net
Sun Jan 25 18:27:45 PST 2004
An update:
The forward script:
opts="+proj=omerc +a=6377298.556 +rf=300.8017 +lat_0=4 +lonc=115 \
+alpha=53d18'56.9537 +gamma_c=53d7'48.3685 +k_0=0.99984 \
+x_0=590476.87 +y_0=442857.65"
replicates the example for Borneo in EPSG #7 and
opts="+proj=omerc +a=6378206.4 +es=.006768657997291094 \
+k=.9999 +lonc=-133d40 +lat_0=57 +alpha=-36d52'11.6315 \
+x_0=818585.5672270928 +y_0=575219.2451072642 +units=us-ft"
replicates the fortran version of gctp to 0.0005 us-ft.
You can see that +gamma_c is the only difference in the usage.
I would appreciate Malaysia specs and bench values as well as more
bench values for Borneo.
Thanks.
About another weeks work to check inverse and other options and
clean up documentation.
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
