[OSRS-PROJ] Bug in CEA projection?
Gerald Evenden
gerald.evenden at verizon.net
Wed Jan 28 08:51:44 PST 2004
I think the problem is what source? The last libproj4 release was
April, '03 which would have caught the version I used in the test
of my previous email.
Unfortunately, the remotesensing.org site does not use libproj4.
I expect to make a new release in the near future once the documentation
and final cleanup of Oblique Mercator (Hotine) are completed.
On Jan 28, 2004, at 11:17 AM, David Orme wrote:
> That's odd - I've just recently compiled proj4 from source but I still
> get the wrong answer.
>> doibook:~ dorme$ proj +proj=cea +ellps=WGS84 +lat_ts=30 -I -f
>> '%.6f'<<EOF
>> > 0 7284713.234
>> > EOF
>> 0.000000 82.485563
>> Rel. 4.4.7, 31 March 2003
>> usage: proj [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
>> doibook:~ dorme$
> The linker details from the dynamic library are:
>> doibook:~ dorme$ otool -L /usr/local/lib/libproj.dylib
>> /usr/local/lib/libproj.dylib:
>> /usr/local/lib/libproj.0.dylib (compatibility version 5.0.0,
>> current version 5.1.0)
>> /usr/lib/libSystem.B.dylib (compatibility version 1.0.0,
>> current version 71.0.0)
> Am I using an outdated version?
> Thanks,
> David
> On 28 Jan 2004, at 15:18, Gerald Evenden wrote:
>> Local lproj (libproj4) script:
>> ../lproj +proj=cea +ellps=WGS84 +lat_ts=30 -I -f '%.6f'<<EOF
>> 0 7284713.234
>> EOF
>> Produces the following results:
>> 0.000000 82.855347
>> Older versions of proj seem to have a problem. Last change
>> to cea (libproj4) was Mar., '03
>> On Jan 28, 2004, at 6:00 AM, Orme, David wrote:
>>> Hi,
>>> This was cross-posted from the Grass list a while back - have I got
>>> something wrong or is this a bug?
>>> I'm using Proj 4.4.7 on my Mac 10.3.2 and ArcGIS 8 on a Windows XP
>>> machine - the two programs give different answers for coordinate
>>> transformations into a Behrmann projection (Cylindrical Equal Area
>>> with latitude of true scale at 30 N/S). I've checked using Geotrans
>>> 2.2.4 on the Windows machine and that agrees with ArcGIS.
>>> My test point is in Behrmann coordinates, units in meters: 0E
>>> 7284713.234N
>>> cs2cs gives:
>>> > doibook:~/Library/Preferences dorme$ cs2cs -f "%0.6f" +proj=cea
>>> > +lat_ts=30 +datum=WGS84 +to +proj=latlong +datum=WGS84
>>> > 0 7284713.234
>>> > 0.000000 82.485563 0.000000
>>> Both ArcGIS and Geotrans give the following geodesic coordinates: 0 E
>>> 82.855347 N
>>> Any suggestions?
>>> Many thanks,
>>> David Orme
>> _____________________________________
>> Jerry and the low riders: Daisy Mae and Joshua
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
