[OSRS-PROJ] Bug in CEA projection?
David Orme
d.orme at imperial.ac.uk
Thu Jan 29 04:00:07 PST 2004
Ah - sorry, I didn't get the difference. I've downloaded libproj4 - had
a few problems building lproj because the proj4 library was masking the
libproj4 versions and so I got undefined symbols for _pj_dmstor,
_pj_rtodms and _pj_set_rtodms. I changed the Makefile for libproj4 to
build to libproj4.a rather than libproj.a and then the library linker
flag in make lproj to -lproj4 - that gives me a working version that
gives the correct answer:
> doibook:/usr/local/src/libproj4/source dorme$ ./lproj +proj=cea
> +ellps=WGS84 +lat_ts=30 -I -f '%.6f'<<EOF
> > 0 7284713.234
> > EOF
> 0.000000 82.855347
Thanks for your help - I'll post this as a bug with solution...
Thanks,
David
On 28 Jan 2004, at 16:51, Gerald Evenden wrote:
> I think the problem is what source? The last libproj4 release was
> April, '03 which would have caught the version I used in the test
> of my previous email.
> Unfortunately, the remotesensing.org site does not use libproj4.
> I expect to make a new release in the near future once the
> documentation
> and final cleanup of Oblique Mercator (Hotine) are completed.
> On Jan 28, 2004, at 11:17 AM, David Orme wrote:
>> That's odd - I've just recently compiled proj4 from source but I
>> still get the wrong answer.
>>> doibook:~ dorme$ proj +proj=cea +ellps=WGS84 +lat_ts=30 -I -f
>>> '%.6f'<<EOF
>>> > 0 7284713.234
>>> > EOF
>>> 0.000000 82.485563
>>> Rel. 4.4.7, 31 March 2003
>>> usage: proj [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
>>> doibook:~ dorme$
>> The linker details from the dynamic library are:
>>> doibook:~ dorme$ otool -L /usr/local/lib/libproj.dylib
>>> /usr/local/lib/libproj.dylib:
>>> /usr/local/lib/libproj.0.dylib (compatibility version 5.0.0,
>>> current version 5.1.0)
>>> /usr/lib/libSystem.B.dylib (compatibility version 1.0.0,
>>> current version 71.0.0)
>> Am I using an outdated version?
>> Thanks,
>> David
>> On 28 Jan 2004, at 15:18, Gerald Evenden wrote:
>>> Local lproj (libproj4) script:
>>> ../lproj +proj=cea +ellps=WGS84 +lat_ts=30 -I -f '%.6f'<<EOF
>>> 0 7284713.234
>>> EOF
>>> Produces the following results:
>>> 0.000000 82.855347
>>> Older versions of proj seem to have a problem. Last change
>>> to cea (libproj4) was Mar., '03
>>> On Jan 28, 2004, at 6:00 AM, Orme, David wrote:
>>>> Hi,
>>>> This was cross-posted from the Grass list a while back - have I got
>>>> something wrong or is this a bug?
>>>> I'm using Proj 4.4.7 on my Mac 10.3.2 and ArcGIS 8 on a Windows XP
>>>> machine - the two programs give different answers for coordinate
>>>> transformations into a Behrmann projection (Cylindrical Equal Area
>>>> with latitude of true scale at 30 N/S). I've checked using Geotrans
>>>> 2.2.4 on the Windows machine and that agrees with ArcGIS.
>>>> My test point is in Behrmann coordinates, units in meters: 0E
>>>> 7284713.234N
>>>> cs2cs gives:
>>>> > doibook:~/Library/Preferences dorme$ cs2cs -f "%0.6f" +proj=cea
>>>> > +lat_ts=30 +datum=WGS84 +to +proj=latlong +datum=WGS84
>>>> > 0 7284713.234
>>>> > 0.000000 82.485563 0.000000
>>>> Both ArcGIS and Geotrans give the following geodesic coordinates: 0
>>>> E
>>>> 82.855347 N
>>>> Any suggestions?
>>>> Many thanks,
>>>> David Orme
>>> _____________________________________
>>> Jerry and the low riders: Daisy Mae and Joshua
>> PROJ.4 Discussion List
>> See http://www.remotesensing.org/proj for subscription, unsubscription
>> and other information.
More information about the Proj
