[Proj] PROJ from the comand line (Symbol ERROR)
Dave Sampson
gis at watersheds.ca
Tue Jul 19 11:37:05 PDT 2005
Frank,
Thanks for the OGR tipe.. I'll try it. What happens in the case that
there is no PRJ file (as is often the case qith X, Y datasets.
Where would I learn more about matching up the libs properly?
I did a FIND for pj_list and -pj_release and had no hits so I don't know
where to start. I can build links, just need to know WHAT to link where.
should I uninstall proj and recompile? What is involved in a full
removal if I go this route?
cheers
>On 7/19/05, Dave Sampson <gis at watersheds.ca> wrote:
>>ERROR:
>>In reference to my last post....
>>sampson at dryad proj-4.4.9 $ proj
>>proj: Symbol `pj_list' has different size in shared object, consider
>>re-linking
>>proj: Symbol `pj_release' has different size in shared object, consider
>>re-linking
>>Rel. 4.4.9, 29 Oct 2004
>>usage: proj [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
>Dave,
>This would appear to indicate you have a mismatched PROJ
>executable and shared library. If that can't be the case, then I am
>at a loss.
>Best regards,
|Dave Sampson: Geographic Information System (GIS) Technician |
|Centre for Sustainable Watersheds |
|Cooperative Approaches to Protect Canada's Water Resources |
|14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0 |
|Lat: 44.700 Long: -76.19 |
|www.watersheds.ca gis at watersheds.ca |
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20050719/981db6a5/attachment.html>
More information about the Proj
