[Proj] PROJ from the comand line (Symbol ERROR)
Carl Godkin carl at dgi.com
Tue Jul 19 11:42:43 PDT 2005
Dave Sampson wrote:
> Where would I learn more about matching up the libs properly?
You might try running "ldd" on your proj executable and seeing
if the shared library(ies) are the ones you expect.
Hope that helps,
carl
