[Proj] UTM Zone projection parameters to pass to pj_transform()
Eric Miller
EMiller at dfg.ca.gov
Mon Nov 28 12:33:43 PST 2005
The results look like they're still in radians. Multiply by 180 / M_PI (or use the RAD_TO_DEG macro). You can use the pj_is_latlong() function to test if a projection is latlong and then conditionally convert from/to radians.
Eric G. Miller
GIS Analyst
Wildlife and Habitat Data Analysis Branch
Department of Fish and Game
>>> david.jacques at ftw.usda.gov 11/28/2005 12:13:28 PM >>>
The output from listgeo is this...
Corner Coordinates:
Upper Left ( 360427.280,3278421.510)
Lower Left ( 360427.280,3270801.510)
Upper Right ( 367182.280,3278421.510)
Lower Right ( 367182.280,3270801.510)
Center ( 363804.780,3274611.510)
The corner coordinates in Decimal Degrees should be
Upper Left ( 29.628626,-94.441707)
Lower Left ( 29.559135,-94.441707)
Upper Right ( 29.628626,-94.371019)
Lower Right ( 29.559135,-94.371019
What I get is...
-1.648319,0.517104
-1.648302,0.515904
-1.647101,0.517117
-1.647085,0.515917
This prompted me to look at the PJ structure in debug mode (watch)
In my Visual Studio 7 IDE. I saw the following string in the
description...
+ descr 0x0043802c "Universal Transverse Mercator (UTM) Cyl, Sph
zone= south" const char *
Funny how I didn't specify "south".
This led me to believe I need to specify more parameters.
David
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
