[Proj] UTM Zone projection parameters to pass to pj_transform()
Ed McNierney
ed at topozone.com
Mon Nov 28 12:43:00 PST 2005
David -
Those output numbers look like radians, not degrees.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Jacques, David -
Fort Worth, TX
Sent: Monday, November 28, 2005 3:13 PM
To: proj at lists.maptools.org
Subject: [Proj] UTM Zone projection parameters to pass to pj_transform()
The output from listgeo is this...
Corner Coordinates:
Upper Left ( 360427.280,3278421.510)
Lower Left ( 360427.280,3270801.510)
Upper Right ( 367182.280,3278421.510)
Lower Right ( 367182.280,3270801.510)
Center ( 363804.780,3274611.510)
The corner coordinates in Decimal Degrees should be
Upper Left ( 29.628626,-94.441707)
Lower Left ( 29.559135,-94.441707)
Upper Right ( 29.628626,-94.371019)
Lower Right ( 29.559135,-94.371019
What I get is...
-1.648319,0.517104
-1.648302,0.515904
-1.647101,0.517117
-1.647085,0.515917
This prompted me to look at the PJ structure in debug mode (watch) In my
Visual Studio 7 IDE. I saw the following string in the description...
+ descr 0x0043802c "Universal Transverse Mercator (UTM) Cyl, Sph
zone= south" const char *
Funny how I didn't specify "south".
This led me to believe I need to specify more parameters.
David
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
