[Proj] Rectification of maps
Clifford J Mugnier
cjmce at lsu.edu
Thu Sep 22 10:04:25 PDT 2005
On 9/22/05, Thomas Flemming <tf at ttqv.com> wrote:
> Hello,
> I often have maps with unknown projection information but printed lat/lon
> grids. Or papermaps, which have strong deformations so that after
scanning the
> projection does not fit anymore.
> Is there a way in proj to calculate x-y/lat-lon by defining a couple of
known
> referencepoints ?
Thomas,
It seems like what you would want is a rubber sheeting transform
of some kind based on a bunch of reference points. Two reference
points wouldn't give you much information. PROJ.4 does not
address this issue. I do have such a capability in GDAL -
underlying transformations based on reference points and a way
of applying it to resample rasters.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
I would recommend an eight-parameter projective transformation based on
four points of a graticule. The panelling of such is identical to the old
graphical technique employed by cartographers of 20 years ago.
Cliff Mugnier
LOUISIANA STATE UNIVERSITY
More information about the Proj
