[Proj] Rectification of maps
Thomas Flemming tf at ttqv.com
Fri Sep 23 09:50:03 PDT 2005
Hello,
> It seems like what you would want is a rubber sheeting transform
> of some kind based on a bunch of reference points.  Two reference
> points wouldn't give you much information.  PROJ.4 does not
> address this issue.  I do have such a capability in GDAL -
> underlying transformations based on reference points and a way
> of applying it to resample rasters.
Puh, this sounds good, btu I think GDAL is too big for me to understand for
this single task.
> I would recommend an eight-parameter projective transformation based on
> four points of a graticule.  The panelling of such is identical to the old
> graphical technique employed by cartographers of 20 years ago.
I have this eight-parameter projective transformation already in my software,
but it does not work good for maps which are stitched from many scanned papermaps.
In this case I need much more control points.
Best regards,
Thomas
**   Dipl.-Ing. Thomas Flemming
**   Software Development
**   Touratech AG
**   Auf dem Zimmermann 7-9
**   D-78078 Niedereschach
**   mail  tf at ttqv.com
**   fon   +49 (0) 7728 9279-206
**   fax   +49 (0) 7728 9279-29
**   http://www.ttqv.com
**   http://www.touratech.de
**   ... und immer dem Pfeil nach!
