[Proj] building proj-4.5.0 for ubuntu 6.06 - PROBLEMS HAVE OCCURED
Christian.Strobl at dlr.de Christian.Strobl at dlr.de
Fri Dec 22 07:52:49 PST 2006
hi all,
i want to compile proj-4.5.0 for ubuntu 6.06. with make check i get the
following error message
Running ./testntv2 using ../src/cs2cs:
doing tests into file ntv2_out, please wait diff ntv2_out with
ntv2_out.dist
3,6c3,6
< 82d00'00.000"W 42d00'00.000"N 0.0     82dW    42d0'0.000003"N 0.000
< 82d00'01.000"W 42d00'00.000"N 0.0     82d0'1"W        42d0'0.000003"N
0.000
< 82d00'02.000"W 42d00'00.000"N 0.0     82d0'2"W        42d0'0.000003"N
0.000
< 84d00'00.000"W 42d00'00.000"N 0.0     84dW    42d0'0.000003"N 0.000
> 82d00'00.000"W 42d00'00.000"N 0.0     81d59'59.61037"W
42d0'0.1602"N 0.000
> 82d00'01.000"W 42d00'00.000"N 0.0     82d0'0.610403"W 42d0'0.160204"N
0.000
> 82d00'02.000"W 42d00'00.000"N 0.0     82d0'1.610436"W 42d0'0.160209"N
0.000
> 84d00'00.000"W 42d00'00.000"N 0.0     83d59'59.85928"W
42d0'0.18003"N 0.000
9,11c9,11
< 99d00'00.000"W 65d00'00.000"N 0.0     99dW    65d0'0.000003"N 0.000
< 111d00'00.000"W 46d00'00.000"N 0.0    111dW   46d0'0.000003"N 0.000
< 111d00'00.000"W 47d30'00.000"N 0.0    111dW   47d30'0.000003"N 0.000
> 99d00'00.000"W 65d00'00.000"N 0.0     99d0'1.58847"W  65d0'1.34815"N
0.000
> 111d00'00.000"W 46d00'00.000"N 0.0    111d0'3.15487"W 45d59'59.75279"N
0.000
> 111d00'00.000"W 47d30'00.000"N 0.0    111d0'2.7989"W  47d29'59.9896"N
0.000
test file ntv2_out saved
make[2]: *** [check-local] Error 100
make[2]: Leaving directory `/usr/src/proj-4.5.0/nad'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/usr/src/proj-4.5.0/nad'
make: *** [check-recursive] Error 1
ignoring that and continuing with make and make install works fine at a
first glance.
is that make check message anything i have to get worried about.
greetings from munich and merry christmas christian
