[Proj] building proj-4.5.0 for ubuntu 6.06 - PROBLEMS HAVE OCCURED
Frank Warmerdam
warmerdam at pobox.com
Fri Dec 22 11:43:44 PST 2006
Christian.Strobl at dlr.de wrote:
> hi all,
> i want to compile proj-4.5.0 for ubuntu 6.06. with make check i get the
> following error message
> Running ./testntv2 using ../src/cs2cs:
Christian,
The problem is that you don't have the NTv2 datum shift files, which
require some special steps to acquire and last I check were not
redistributable. Really this test likely shouldn't even be in the
distribution since it often confuses people. Just disregard testntv2
errors.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
