[Proj] Using proj on Windows
Anthony Dunk
AnthonyD at rocketmail.com
Wed Feb 8 20:21:52 PST 2006
Hi Jeff,
You need to dynamically load the PROJ DLL using some code such as the
following:
// PROJ4 DLL interface
static HINSTANCE g_ProjDLL = NULL;
typedef struct { double u, v; } projUV;
// Proj DLL function pointers
static projPJ (*pfn_pj_init_plus)(const char *) = NULL;
static projPJ (*pfn_pj_init)(int, char**) = NULL;
static projUV (*pfn_pj_fwd)(projUV, projPJ) = NULL;
static projUV (*pfn_pj_inv)(projUV, projPJ) = NULL;
static void (*pfn_pj_free)(projPJ) = NULL;
static int (*pfn_pj_transform)(projPJ, projPJ, long, int,
double *, double *, double * ) =
NULL;
static int *(*pfn_pj_get_errno_ref)(void) = NULL;
static char *(*pfn_pj_strerrno)(int) = NULL;
static char *(*pfn_pj_get_def)(projPJ,int) = NULL;
static void (*pfn_pj_dalloc)(void *) = NULL;
static BOOL LoadProjDLL()
g_ProjDLL = LoadLibrary("proj.dll");
if (g_ProjDLL==NULL) return FALSE;
pfn_pj_init = (projPJ (*)(int, char**)) GetProcAddress( g_ProjDLL,
"pj_init");
if( pfn_pj_init == NULL ) return( FALSE );
pfn_pj_init_plus = (projPJ (*)(const char *)) GetProcAddress(
g_ProjDLL, "pj_init_plus");
pfn_pj_fwd = (projUV (*)(projUV,projPJ)) GetProcAddress(
g_ProjDLL, "pj_fwd" );
pfn_pj_inv = (projUV (*)(projUV,projPJ)) GetProcAddress(
g_ProjDLL, "pj_inv" );
pfn_pj_free = (void (*)(projPJ)) GetProcAddress( g_ProjDLL,
"pj_free" );
pfn_pj_transform = (int (*)(projPJ,projPJ,long,int,double*,
double*,double*)) GetProcAddress(
g_ProjDLL, "pj_transform" );
pfn_pj_get_errno_ref = (int *(*)(void)) GetProcAddress(
g_ProjDLL, "pj_get_errno_ref" );
pfn_pj_strerrno = (char *(*)(int)) GetProcAddress( g_ProjDLL,
"pj_strerrno" );
pfn_pj_get_def = (char *(*)(projPJ,int)) GetProcAddress(
g_ProjDLL, "pj_get_def" );
pfn_pj_dalloc = (void (*)(void*)) GetProcAddress( g_ProjDLL,
"pj_dalloc" );
return TRUE;
Cheers,
Anthony.
--- Jeff Holt <jjholt at hiwaay.net> wrote:
> I need to use proj.dll within a VC++ (version 6) project, however I
> can't
> find a .lib file to link against. Is there a distribution that has a
> proj.lib? Or do I have to get the source and create one myself?
> Thanks!
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
More information about the Proj
