[Proj] Roussilhe Projection
Steffen Macke sdteffen at gmail.com
Fri Feb 10 22:30:37 PST 2006
Hello All,
> > to proj.4.4.9. I attached a patch with the changes I did to make things
> > compile. However, while Gerald Evenden's package works fine, my patched
> > proj does not work.
Missing function prototypes for the mdist part caused the problem.
An improved patch is available from here:
http://sdteffen.de/gis/proj4rouss.diff
Regards,
Steffen
