[Proj] Re: Re: Compile-error on Solaris2.6 (SPARC)
Stephan Holl
holl at gdf-hannover.de
Wed Feb 8 23:51:28 PST 2006
Hello Paul,
On Wed, 8 Feb 2006 12:03:36 -0500 proj-request at lists.maptools.org wrote:
> Perhaps something else you could also try would be a more recent
> version of libtool. I have found that to work with strange PROJ
> compile errors in the past. Except I think the current version is
> only a year or two old, so there probably wouldn't be an improvement.
> But you never know. You just need to copy the most recent version you
> can find of the 'libtool' script into the PROJ source directory,
> overwriting the version there, and then run configure and make as far
> as I know.
Thanks for your suggestion. But we have successfully finished
compiling without optimization using
env CFLAGS="-g -O1" ./configure (on ksh)
So you are better not using optimization on solaris due to avoid
strange compile errors :-)
THank you all for your help.
Best
Stephan
More information about the Proj
