[Proj] NAD27 to WGS84 ?
Octavio Paez Osuna opo at hp.fciencias.unam.mx
Wed Feb 22 11:23:30 PST 2006
Thank you Eric and everybody that contributed to answer my questions. It
is a good thing that a list like this one with such nice people
posting exists.
Octavio
On Wed, 22 Feb 2006, Eric Miller wrote:
> There are published "3-parameter" datum transformation values for NAD27 (Mexico) at:
> http://earth-info.nga.mil/GandG/coordsys/onlinedatum/CountryNorthAmericaTable.html#NASL
> You can use the DX,DY,DZ values via the +towgs84 parameter for the source projection.  Then, use the pj_transform() function to convert from LCC/NAD27 to GEO/WGS84.
> Something like:
> src = pj_init_plus("+proj=lcc <your parameters here> +towgs84=-12,130,190");
> dst = pj_init_plus("+proj=latlong +datum=WGS84")
> There's a fair amount of error in those conversions, but they're okay for small-scale mapping.
> >>> opo at hp.fciencias.unam.mx 2/22/2006 9:30 AM >>>
> Hello,
> I'm new to the list, and to proj, and to Geography. I'm working in some
> maps for GPS receivers (Garming). One of the tools (graphical
> interface) for map creation (visualization) assumes the data is in
> lat/long datum WGS84.
> All the vector data available for Mexico is in lcc NAD27. The data is
> available in shapefiles for which I implemented a C program that
> successfully extracts the coordinates and translate them to lat/long
> in the NAD27 datum using the proj library.
> The questions are: Is it possible to shift (?) the data to WGS84 using
> proj?
> Which command/parameters should I use to do it?
> Any help will be really appreciated,
> Thanks,
> Octavio
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
