[Proj] NAD27 to WGS84 ?
Clifford J Mugnier cjmce at lsu.edu
Wed Feb 22 12:50:35 PST 2006
Octavio,
Note that using those published 3-parameter values will yield no better
than 12-meter accuracy.  What I earlier suggested with respect to the
National Geodetic Survey has the potential accuracy improvement of more
than ten times better - IF such a data file exists for their software.
If accuracy to no better than 12 meters is sufficient for your needs, then
there's no need to contact NGS.
C. Mugnier
Thank you Eric and everybody that contributed to answer my questions. It
is a good thing that a list like this one with such nice people
posting exists.
Octavio
On Wed, 22 Feb 2006, Eric Miller wrote:
> There are published "3-parameter" datum transformation values for NAD27
(Mexico) at:
http://earth-info.nga.mil/GandG/coordsys/onlinedatum/CountryNorthAmericaTable.html#NASL
> You can use the DX,DY,DZ values via the +towgs84 parameter for the source
projection.  Then, use the pj_transform() function to convert from
LCC/NAD27 to GEO/WGS84.
> Something like:
> src = pj_init_plus("+proj=lcc <your parameters here>
+towgs84=-12,130,190");
> dst = pj_init_plus("+proj=latlong +datum=WGS84")
> There's a fair amount of error in those conversions, but they're okay for
small-scale mapping.
> >>> opo at hp.fciencias.unam.mx 2/22/2006 9:30 AM >>>
> Hello,
> I'm new to the list, and to proj, and to Geography. I'm working in some
> maps for GPS receivers (Garming). One of the tools (graphical
> interface) for map creation (visualization) assumes the data is in
> lat/long datum WGS84.
> All the vector data available for Mexico is in lcc NAD27. The data is
> available in shapefiles for which I implemented a C program that
> successfully extracts the coordinates and translate them to lat/long
> in the NAD27 datum using the proj library.
> The questions are: Is it possible to shift (?) the data to WGS84 using
> proj?
> Which command/parameters should I use to do it?
> Any help will be really appreciated,
> Thanks,
> Octavio
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Proj mailing list
