[Proj] Finnish KKJ in proj 4.4.9 - Linux vs. Windows
Eric Miller
EMiller at dfg.ca.gov
Tue Jan 3 10:11:14 PST 2006
Are they really in minutes? If I divide by 60 and run through cs2cs using esri:2393, I don't get anything close to your reference values. I also assumed you meant the values were in longitude (col 7) and latitude (col 8) order.
Also, even though pj_transform assumes datum=WGS84 if no datum is specified, it'd be more correct to actually specify +datum=WGS84.
>>> roger at opq.se 1/3/2006 5:11:21 AM >>>
On Wed, 2005-12-14 at 15:44 +0100, Roger Oberholtzer wrote:
Columns 7 and 8 are WGS84 lats and longs in minutes. I have verified
that both the Linux and Windows calculations are using the exact same
values for these. These are the values that all calculations are based
on.
More information about the Proj
