[Proj] Finnish KKJ in proj 4.4.9 - Linux vs. Windows
John Smart
john.smart at caris.com
Tue Jan 3 10:25:54 PST 2006
I think it may be DDMM.mmmmm
6012.21644 2452.87822
60 degrees 12.21644 minutes N
24 degrees 52.87822 minutes E
(which is just west of Helsinki).
----- Original Message -----
To: <proj at lists.maptools.org>
Sent: Tuesday, January 03, 2006 2:11 PM
Subject: Re: [Proj] Finnish KKJ in proj 4.4.9 - Linux vs. Windows
> Are they really in minutes? If I divide by 60 and run through cs2cs using
> esri:2393, I don't get anything close to your reference values. I also
> assumed you meant the values were in longitude (col 7) and latitude (col
> 8) order.
> Also, even though pj_transform assumes datum=WGS84 if no datum is
> specified, it'd be more correct to actually specify +datum=WGS84.
>>>> roger at opq.se 1/3/2006 5:11:21 AM >>>
> On Wed, 2005-12-14 at 15:44 +0100, Roger Oberholtzer wrote:
> Columns 7 and 8 are WGS84 lats and longs in minutes. I have verified
> that both the Linux and Windows calculations are using the exact same
> values for these. These are the values that all calculations are based
> on.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
