[Proj] New ellipsoid
Gerald I. Evenden
gerald.evenden at verizon.net
Tue Jul 4 19:14:29 PDT 2006
With any level of the proj4 software you can change the ellipsoid to any value
you wish within "reasonable" limits. Major axis is not a problem in any case
as internally the projections are evaluated for a "unit ellipsoid" and the
results multiplied by the real major axis. A problem may occur if the
eccentricity increases significantly over the range of the earth's value
because many calculations are approximations that assume a value of e^2 in
the range of 0.006. I would suspect that for e^2 < 0.01 would work but I
would be careful beyond that range. Smaller e should never be a problem.
Note: in most cases the computational factor involving eccentricity is in the
form of e^2 or e (eccentricity) so that is what I must referred to here. To
phrase the range in terms of flattening, minor axis, etc. you will need to do
a little math with the equations given in the documentation relating them to
eccentricity.
On Friday 30 June 2006 3:33 pm, Fabrizio Bernardini wrote:
> I am new in this list and I do not know if this topic has been discussed
> yet. I tried to search for it but got no useful results.
> My question is:
> How can I change ellipsoid and specify a completely
> new one, for instance for a planet which is NOT Earth.
> Will the projection library still work in this case?
> Did anybody ever discussed this issue?
> Is there a reference to that anywhere?
> Thanks,
> Fabrizio
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Jerry and the low-riders: Daisy Mae and Joshua
"Cogito cogito ergo cogito sum"
Ambrose Bierce, The Devil's Dictionary
More information about the Proj
