[Proj] Command line conversion problem
Anthony Dunk AnthonyD at rocketmail.com
Tue Jul 4 19:42:54 PDT 2006
Mike,
The EPSG code 26711 is for UTM Zone 11 NAD 27. By the looks of your
input coordinates you should have used EPSG code 4267 (Lat/Lon NAD 27)
instead.
The other thing to look out for is that you're giving the coordinates
to cs2cs in the correct order. Usually cs2cs requires longitude
followed by latitude as the input order.
Anthony.
--- Mike D'Ambrogia <miked at jamagination.com> wrote:
> Trying to convert NAD27 DD.DDDDD to WGS84 UTM
> I use:
> cs2cs +init=epsg:26711 +to +init=epsg:32611
> Trying to convert 38.1703 -119.7385 and all I can get out is "*
> 0.00", I should get 260102E 4228255N
> I'm goofing something up, hoping it's simple and someone can quickly
> point me in the right direction
> Thanks in advance
> Mike
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
