[Proj] Using libproj with array data
James Gallagher
jhrg at mac.com
Wed Jul 5 13:37:56 PDT 2006
Hi, I hope this is not a FAQ or covered in the existing docs; I've
checked and apologize if I missed something obvious.
I have a data server which is used to access a number of files of
georeferenced data stored in two dimentional arrays. For each array,
I know the longitude and latitude values at the corners as well as
the projection and datum. Is there a way I can use libproj to map
long/lat locations to indices within the arrays?
Thanks,
James
James Gallagher jgallagher at opendap.org
OPeNDAP, Inc 406.723.8663
More information about the Proj
