[Proj] Using libproj with array data
Anthony Dunk
AnthonyD at rocketmail.com
Wed Jul 5 20:24:45 PDT 2006
James,
What you're trying to do sounds like re-projecting a grid. (A grid just
being a two dimensional array of values). I have written code to do
this previously.
To project a grid you basically have to perform a forward projection of
some points around the edge of the input grid and use these to compute
the bounding rectangle in the new coordinate system. (Remember some
projections will distort the shape of the grid).
You then create an output grid in the new coordinate system with the
appropriate dimensions.
Finally you have to go through each cell in the output grid and use
reverse projection to find the corresponding cell in the unprojected
grid. Use grid interpolation to pick up the value you need to put in
the output grid cell.
There's probably already code in the public domain which uses PROJ to
do this.
Anthony.
--- James Gallagher <jhrg at mac.com> wrote:
> Hi, I hope this is not a FAQ or covered in the existing docs; I've
> checked and apologize if I missed something obvious.
> I have a data server which is used to access a number of files of
> georeferenced data stored in two dimentional arrays. For each array,
> I know the longitude and latitude values at the corners as well as
> the projection and datum. Is there a way I can use libproj to map
> long/lat locations to indices within the arrays?
> Thanks,
> James
> James Gallagher jgallagher at opendap.org
> OPeNDAP, Inc 406.723.8663
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
More information about the Proj
