[Proj] having problems with proj-4.4.9
Albert Anderson bart_doggers at yahoo.com
Fri Jul 14 12:03:36 PDT 2006
 I installed the program step by step.  I am trying to project file that I am creating in a map file.  I am also using map server.  I dont know if proj-4.4.9 is install right and working.  here is my map file code
#This is Richland County Map Server
NAME "Richland"
SIZE 309 417
UNITS DD
IMAGECOLOR 189 202 222
IMAGETYPE JPEG
PROJECTION "init=epsg:26914"
END
SHAPEPATH "/home/mapdata/"
EXTENT     -97.338391 45.907505 -96.508389 46.717217
# Symbol for drawing fat lines
SYMBOL
     NAME "BigLine"
     TYPE ELLIPSE
     POINTS 1 1 END
END
# Symbol for drawing dashed lines
SYMBOL
     NAME "DashedLine"
     TYPE ELLIPSE
     POINTS 1 1 END
     STYLE 10 10 END
END
# Symbol for drawing spots
SYMBOL
     NAME "Circle"
     FILLED true
     TYPE ellipse
     POINTS 1 1 END
END
# Web object
WEB
  TEMPLATE '/var/www/htdocs/gismapserver_test_project_mod.html'
  IMAGEPATH '/var/www/htdocs/tmp/'
  IMAGEURL '/tmp/'
END
# Reference map
REFERENCE
     IMAGE "/home/mapdata/richland.gif"
     SIZE 136 152
     EXTENT -97.228391 45.907505 -96.628389 46.717217
     STATUS ON
     COLOR -1 -1 -1
     OUTLINECOLOR 0 0 0
END
# Scalebar
SCALEBAR
     LABEL
          COLOR 0 0 0
          ANTIALIAS true
          SIZE small
     END
     POSITION lr
     INTERVALS 5
     STATUS embed
     SIZE 175 5
     STYLE 0
     UNITS miles
     BACKGROUNDCOLOR 0 255 0
     IMAGECOLOR 255 255 255
     COLOR 128 128 128
     OUTLINECOLOR 0 0 255
     TRANSPARENT off
END
LAYER
    NAME "richland"
    STATUS default
    TYPE polygon
    DATA "RICH_bndy"
    END
    CLASS
      STYLE
            COLOR 255 0 0
      END
   END
END
LAYER
    NAME "boundary"
    STATUS on
    TYPE line
    DATA "RC_boundary_05"
    CLASS
      STYLE
            COLOR 0 0 0
      END
   END
END
LAYER
    NAME "roads"
    STATUS on
    TYPE line
    DATA "roads_shp"
    CLASS
      STYLE
            COLOR 255 0 0
      END
   END
END
LAYER
    NAME "sections"
    STATUS on
    TYPE line
    DATA "RC_sections_05"
    CLASS
      STYLE
            COLOR 255 130 171
      END
   END
END
LAYER
    NAME "parecles"
    STATUS on
    TYPE line
    DATA "RC_parcels_05"
    CLASS
      STYLE
            COLOR 0 0 0
      END
   END
END
END
So what would be my first step to this problem.  I am not getting the projective file showning up.
Thanks,
Albert
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2ยข/min or less.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060714/5fafcb79/attachment.html>
