[Proj] .NET / C# port of proj4
Glynn Clements
glynn at gclements.plus.com
Wed Jun 7 16:27:48 PDT 2006
Jason Askew wrote:
> So, question one:
> In file: pj_transform.c
> projected_loc is defined as so:
> XY projected_loc;
> XY being defined as:
> typedef struct { double x, y; } XY;
Not in pj_transform.c; see below.
> buy then later in pj_transform.c, u and v members show up in
> pj_transforms.c, like so:
> projected_loc.u = x[point_offset * i];
> projected_loc.v = y[point_offset * i];
> I must be missing something painfully obvious. I see the defines
> wrapped around the def of the XY struct, i.e.:
> #ifndef PJ_LIB__
> #define XY projUV
> #define LP projUV
> #else
> typedef struct { double lam, phi; } LP;
> #endif
> but PJ_LIB__ is defined.
It's defined on a file-by-file basis. The PJ_*.c files define it, as
do some of the pj_*.c files, but pj_transform.c doesn't.
> Not to mention pj_inv and pj_inv expect the XY for and not the projUV form.
pj_inv.c defines PJ_LIB__.
More information about the Proj
