[Proj] .NET / C# port of proj4
Jason Askew
jason.askew at gmail.com
Wed Jun 7 16:41:18 PDT 2006
To paraphrase: So the signature changes but the struct stays the same
at the memory level, so it just works.
Ok, I can deal with that.
On 6/7/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Jason Askew wrote:
> > So, question one:
> > In file: pj_transform.c
> > projected_loc is defined as so:
> > XY projected_loc;
> > XY being defined as:
> > typedef struct { double x, y; } XY;
> Not in pj_transform.c; see below.
> > buy then later in pj_transform.c, u and v members show up in
> > pj_transforms.c, like so:
> > projected_loc.u = x[point_offset * i];
> > projected_loc.v = y[point_offset * i];
> > I must be missing something painfully obvious. I see the defines
> > wrapped around the def of the XY struct, i.e.:
> > #ifndef PJ_LIB__
> > #define XY projUV
> > #define LP projUV
> > #else
> > typedef struct { double lam, phi; } LP;
> > #endif
> > but PJ_LIB__ is defined.
> It's defined on a file-by-file basis. The PJ_*.c files define it, as
> do some of the pj_*.c files, but pj_transform.c doesn't.
> > Not to mention pj_inv and pj_inv expect the XY for and not the projUV form.
> pj_inv.c defines PJ_LIB__.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
