[Proj] PROJ 4.5.0 beta (and Krovak!)
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Sep 14 06:46:22 PDT 2006
Hello Frank,
Just a suggestion (probably unhelpful because I'm not proposing to help
out with the work involved!) but I thought I should point it out:
Gerald supports this projection in libproj4, where it is identified by
proj=kocc (for Krovak Oblique Conformal Conic) rather than proj=krovak.
For long-term consistency (I know at some stage you intend to include
libproj4 as some kind of "core" to PROJ.4) might it be a good idea to use
his code instead of patching the "contributed" krovak code in PROJ.4?
Paul
On Thu, 14 Sep 2006, Frank Warmerdam wrote:
> Folks,
> I am surrounded by folks from the Czech Republic who have
> finally forced me to fix the Krovak projection!
> So, finally, after many years it is done!
> I have also prepared a beta of PROJ 4.5.0 with this change at:
> http://www.gdal.org/tmp/proj-4.5.0b1.tar.gz
> or
> http://www.gdal.org/tmp/proj-4.5.0b1.zip
> If there are no problems I will likely issue a final release in
> a week or two.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
