[Proj] PROJ 4.5.0 beta (and Krovak!)
Mon Sep 25 10:58:49 PDT 2006
Gerald I. Evenden wrote:
> I may as well offer my two cents also.
> I do not particularly care what the projection is called but I would
> appreciate some communications as to using the 'kocc' designation so I could
> at least change my releases of libproj4 to conform with external usage.
Gerald,
I'm not sure what the best solution to this is.  I applied the
krovak patch after years of "encouragement".  I wasn't aware there was
a distinct approach in libproj4.
Perhaps the Krovak user community could comment on how they would like
this handled?  I've no objection to using proj=kocc for this.
> Also, there was some earlier communications that maybe libproj4 would replace
> the old proj4 based code and recoding of existing applications might occur.
> I presume these ideas are dead and proj4 will remain the primary basis.
This is still my plan though my previous efforts to set a deadline
for myself have clearly not resulted in any progress.
> It is also somewhat disappointing that there is little if any communications
> about efforts modifying either proj4 or libproj4.  In the latter case I do
> not bother discussing my activities with libproj4 as I had no knowledge of
> anyone else hacking the system other than for private purposes.
> Lacking any communications among developers is just going to lead to a
> mishmash of an odd assortment of [lib]proj4 releases with greater and greater
> incompatibility.
It is generally my policy to advise folks who want new projections or
changes to existing projects to you, and then I try to backport the
changes as needed.
The truth is I am only spending a tiny amount of time on PROJ.4, mostly
apply provided patches, and updating EPSG database translations.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
