[Proj] PROJ 4.5.0 beta (and Krovak!)
Martin Landa landa.martin at gmail.com
Thu Sep 28 01:44:26 PDT 2006
there is no objections (as I know from the Czech mailing list) to use
'kocc' projection identifier.
Proposal: would be possible to keep 'krovak' as an alternative
projection name due to backward compatibility?
In any case, big thanks to Frank for applying the patch!:-)
Best regards, Martin
2006/9/14, Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> Hello Frank,
> Just a suggestion (probably unhelpful because I'm not proposing to help
> out with the work involved!) but I thought I should point it out:
> Gerald supports this projection in libproj4, where it is identified by
> proj=kocc (for Krovak Oblique Conformal Conic) rather than proj=krovak.
> For long-term consistency (I know at some stage you intend to include
> libproj4 as some kind of "core" to PROJ.4) might it be a good idea to use
> his code instead of patching the "contributed" krovak code in PROJ.4?
> Paul
> On Thu, 14 Sep 2006, Frank Warmerdam wrote:
> > Folks,
> > I am surrounded by folks from the Czech Republic who have
> > finally forced me to fix the Krovak projection!
> > So,  finally, after many years it is done!
> > I have also prepared a beta of PROJ 4.5.0 with this change at:
> > http://www.gdal.org/tmp/proj-4.5.0b1.tar.gz
> > or
> > http://www.gdal.org/tmp/proj-4.5.0b1.zip
> > If there are no problems I will likely issue a final release in
> > a week or two.
> > Best regards,
> > I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush    | Geospatial Programmer for Rent
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
