[Proj] Tansverse Mercator South Oriented question
Eric Miller EMiller at dfg.ca.gov
Mon Apr 2 11:16:02 PDT 2007
I don't think that PROJ.4 supports Transverse Mercator (South
Orientated).
>>> On 3/31/2007 at 3:59 PM, Zindine <nabble at souiki.org> wrote:
> I have the PROJCS below defined and it does not get validated by OGR.
> I receive the error: OGRERR_UNSUPPORTED_SRS.
> It was simply defined as follow:
> 	OGRSpatialReference    oTMSO;
> 	oTMSO.SetProjCS("TMSO Zone 29 / WGS84");
> 	oTMSO.SetWellKnownGeogCS( "WGS84" );
> 	oTMSO.SetTMSO(0,29,1,0,0);
> Can anyone help me find the error? Thanks.
> PROJCS[
> 		"unnamed"
> 		,GEOGCS[
> 			"WGS 84"
> 			,DATUM[
> 				"WGS_1984"
> 				,SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]]
> 				,TOWGS84[0,0,0,0,0,0,0]
> 				,AUTHORITY["EPSG","6326"]
> 			,PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]]
			,UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]]
> 			,AXIS["Lat",NORTH]
> 			,AXIS["Long",EAST]
> 			,AUTHORITY["EPSG","4326"]
> 		,PROJECTION["Transverse_Mercator_South_Orientated"]
> 		,PARAMETER["latitude_of_origin",0]
> 		,PARAMETER["central_meridian",29]
> 		,PARAMETER["scale_factor",1]
> 		,PARAMETER["false_easting",0]
> 		,PARAMETER["false_northing",0]
