[Proj] Coordinate transformation assistance
Bjørn Krangnes
bkr at devonor.com
Thu Apr 12 05:58:43 PDT 2007
I am trying to convert from ITM to IG using EPSG codes but when trying to
initialize with the EPSG codes (ITM=2157 and IG=29903) I get error code 6.
The ITM has the following definition:
<2157> +proj=tmerc +lat_0=53.5 +lon_0=-8 +k=0.999820 +x_0=600000
+y_0=750000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs <>
IG has the following definition:
<29903> +proj=tmerc +lat_0=53.5 +lon_0=-8 +k=1.000035 +x_0=200000
+y_0=250000 +a=6377340.189 +b=6356034.447938534 +units=m +no_defs <>
These definitions I have found in a file with name EPSG downloaded from
the proj-4.50 project.
Bjørn
> On Thu, 12 Apr 2007, [iso-8859-15] Bjørn Krangnes wrote:
>> Hi,
>> I am trying to go from Irish Transverse Mercator to IrishGrid75 Ireland
>> using GDAL C# and EPSG codes.
>> The code is like this:
>> double[] xyz = new double[3];
>> OGR.SpatialReference inp = new OGR.SpatialReference(null);
>> OGR.SpatialReference outp = new OGR.SpatialReference(null);
>> int stat1 = inp.ImportFromEPSG(2157); // Irish Transverse
>> Mercator
>> int stat2 = outp.ImportFromEPSG(29903); // IrishGrid75
>> Ireland
>> OGR.CoordinateTransformation tra = new
>> OGR.CoordinateTransformation(inp, outp);
>> xyz[0] = 600000.0;
>> xyz[1] = 700000.0;
>> xyz[2] = 22.22;
>> tra.TransformPoint(xyz);
>> I think the problems is with ImportFromEPSG because both istat1 and
>> istat2
>> is 6 after execution. How to initialize the EPSG codes ?
> What is the problem?
> (Sorry I can't help with C-sharp stuff anyway but here's something else
> that may be important:)
> Those codes should work but to be clearer about what you're doing it is
> more obvious to enter the projection in PROJ.4 syntax IMHO. In particular,
> Irish Transverse Mercator uses the WGS84 ellipsoid while Irish Grid uses
> the Modified Airy, so you will need some datum transformation parameters
> with the Irish Grid projection to get an accurate transformation. I
> suggest:
> +proj=tmerc +lat_0=53.5 +lon_0=-8 +k=1.000035 +x_0=200000 +y_0=250000 \
> +no_defs +a=6377340.189 +rf=299.3249646 \
> +towgs84=482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15 +to_meter=1
> Those parameters are published by both Ordnance Surveys (ROI & NI) as
> having an accuracy of approx. 0.4m throughout Ireland.
> Interesting anyway; I didn't know anybody was actually using Irish
> Transverse Mercator for anything yet!
> Paul
>> I am resending this request beacuse I have not had any feedback on my
>> previous request.
>> Regards
>> Bjørn Krangnes
>> Devonor AS
>> Telephone: +47 32 29 96 90
>> Direct Line: +47 32 29 96 91
>> Mobile: +47 45035640
>> E-mail: bkr at devonor.com
>> Web: www.devonor.com
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
Bjørn Krangnes
Devonor AS
More information about the Proj
