[Proj] grass problem with shp
José Alberto Gonçalves
jagoncal at fc.up.pt
Sat Aug 4 06:32:31 PDT 2007
The parameters correspond to UTM zone 2, northern hemisphere. The
ellipsoid is Clarke1866 ellipsoid, so probably the data is in the North
American Datum 1927.
I hope this helps.
Jose' Gonçalves
riad mazloum wrote:
> Hi,
> I'm using grass6.0 in a project an I have ESRI data,
> I have the projection info:
> PROJCS["PCS_Transverse_Mercator",
> GEOGCS["GCS_Clarke_1866",
> DATUM["D_Clarke_1866",
> SPHEROID["Clarke_1866",6378206.4,294.9786982]],
> PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["False_Easting",500000],
> PARAMETER["False_Northing",0],
> PARAMETER["Central_Meridian",-171],
> PARAMETER["Scale_Factor",0.9996],
> PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]
> and i don't know how to create a location for this data
> Please help me, I'm running out of time in my project!
> Thanks
> Looking for a deal? Find great prices on flights and hotels
> <http://us.rd.yahoo.com/evt=47094/*http://farechase.yahoo.com/;_ylc=X3oDMTFicDJoNDllBF9TAzk3NDA3NTg5BHBvcwMxMwRzZWMDZ3JvdXBzBHNsawNlbWFpbC1uY20->
> with Yahoo! FareChase.
>_______________________________________________
>Proj mailing list
>Proj at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
