[Proj] grass problem with shp
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sat Aug 4 07:50:45 PDT 2007
On Sat, 4 Aug 2007, riad mazloum wrote:
> Hi,
> I'm using grass6.0 in a project an I have ESRI data,
> I have the projection info:
> PROJCS["PCS_Transverse_Mercator",
> GEOGCS["GCS_Clarke_1866",
> DATUM["D_Clarke_1866",
> SPHEROID["Clarke_1866",6378206.4,294.9786982]],
> PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["False_Easting",500000],
> PARAMETER["False_Northing",0],
> PARAMETER["Central_Meridian",-171],
> PARAMETER["Scale_Factor",0.9996],
> PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]
> and i don't know how to create a location for this data
Save the above WKT co-ordinate system description to an ASCII file, then
run the GRASS command:
g.proj -c location=newloc wkt=filename
where newloc is the name of the new location you wish to create and
filename is the file you saved the co-ordinate system description to.
You could also try the -j command with g.proj to output the information in
PROJ.4 format, if it was useful. Seeing this was a GRASS question I've
given a GRASS answer. It doesn't really belong on the PROJ list...
Paul
More information about the Proj
