[Proj] Re: Proj Digest, Vol 42, Issue 8
Roger Oberholtzer
roger at opq.se
Fri Dec 7 07:26:09 PST 2007
On Fri, 2007-11-30 at 11:47 +0100, Jordi Gilabert Vall wrote:
> I use these 7 coefficients with cartography in Catalonia (Spain), with
> right results:
> cs2cs +proj=latlong +datum=WGS84 +ellps=WGS84 +to +init=epsg:23031
> +proj=utm +ellps=intl +zone=31 +units=m +towgs84=-
> 131.0320,-100.2510,-163.3540,1.2438,0.0195,1.1436,9.3900
I have finally had a chance to check this. Sorry it took so long. I do
not get much difference. Could you give me a few sample lat/longs and
the northings/eastings you get with this command? I did have to change
the zone to 30 for Madrid for my tests, os the derived values were very
far off.
> More information:
> http://www.euref-iag.net/symposia/book2003/4-6.pdf
> http://www.fomento.es/NR/rdonlyres/8B4D8323-5706-4F8F-84F7-C89774DCC2A1/29826/hercam.pdf
> Jordi Gilabert Vall
> Message: 1
> Date: Thu, 29 Nov 2007 14:55:17 +0100
> From: Roger Oberholtzer <roger at opq.se>
> Subject: RE: [Proj] WGS84 to ED50
> To: "PROJ.4 and general Projections Discussions"
> <proj at lists.maptools.org>
> Message-ID: <1196344518.25474.84.camel at acme.pacific>
> Content-Type: text/plain; charset=UTF-8
> I have a bit more information on the problem with WGS84
> lat/longs ->
> ED50(Spain) northings and eastings.
> The software that is being used does not have a 'Spanish'
> setting. So
> they have defined an ED50 7 parameter transform, with these
> coefficients:
> > International Ellipsoid 1924 definition
> > Mayor semiaxle: 6378388
> > Minor semiaxle:6356911,9461
> > 1/f:297
> > Excentricity: 0.0819910890032286
> > About the 7 parameters transformation
> > Translation X (m): 125.098545
> > Translation Y (m): 76.000054
> > Translation Z (m): 156.198703
> > X Rotation(seconds): 0
> > Y Rotation(seconds): 0
> > Z Rotation(seconds): -1.129
> > Scale factor (ppm): - 8.30463103
> > This correspond with applanix header file saying
> > Mapping frame datum: ED50_ESPAÑA ; a = 6378388.000000; 1/f =
> 297.000000;
> > Coordinate transformation from WGS84 to mapping frame
> datum
> > dX = 125.098545; dY = 76.000054; dZ = 156.198703; f =
> 0.999991695369;
> > R1 = 0.000000000000; R2 = 0.000000000000; R3 =
> -0.000005473550;
> > sequence of the rotations: x,y,z,1
> > Mapping frame projection : TM;
> > central meridian = -3.000000 deg;
> > latitude of the grid origin = 0.000000 deg; grid scale
> factor = 0.999600:
> > false easting = 500000.000000 m; false northing = 0.000000
> m;
> > Where Rotations are in radians
> I have tried setting proj to use this, as reported earlier in
> this thread, with no luck. I tried using the 7 parameters as
> +towgs84=125.098545,76.000054,156.198703,0.0,0.0,-1.129,-8.30463103, but that made things worse.
> fromProj = pj_init_plus(
> "+proj=latlong "
> "+ellps=WGS84 "
> "+no_defs");
> toProj = pj_init_plus(
> "+proj=utm "
> "+ellps=intl "
> "+k=0.999600 "
> "+x_0=500000.0 "
> "+y_0= 0.0 "
> "+zone=30 "
> "+units=m"
> "+towgs84=125.098545,76.000054,156.198703,0.0,0.0,-1.129,-8.30463103"
> "+no_defs");
> So I am guessing I cannot simply use the 7 parameters as
> given. Correct?
> Roger Oberholtzer
> OPQ Systems / Ramböll RST
> Ramböll Sverige AB
> Kapellgränd 7
> P.O. Box 4205
> SE-102 65 Stockholm, Sweden
> Office: Int +46 8-615 60 20
> Mobile: Int +46 70-815 1696
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Roger Oberholtzer
Ramböll Sverige AB
Kapellgränd 7
P.O. Box 4205
More information about the Proj
