[Proj] Re: PROJ 4.6.0 beta1 Release
Ivan Shmakov
ivan at theory.asu.ru
Tue Dec 11 12:09:48 PST 2007
[Apparently this message didn't reached the list, so I'm
resending it.]
>>>>> Frank Warmerdam <warmerdam at pobox.com> writes:
>> What happens with the spherical projections? Robinson and similar?
> The same.
> Though the other aspect that I did was to decouple the the
> datum/ellipsoid logic for datum shifting from the ellipsoid
> parameters used for internal projection calculations.
> Actually, a better demonstration of the above would be:
> cs2cs +proj=robin +datum=GGRS87 +to +proj=latlong +datum=WGS84
> The important distinction is that GGRS87 expands to
> "+towgs84=-199.87,74.79,246.62 +ellps=GRS80". The towgs84 shift is
> applied in geocentric space, but it is very important which ellipsoid
> is used to get to geocentric space. In the "old" approach the sphere
> used for robinson would have been used for the conversion to
> geocentric. Now, GRS80 would be used for the calculation avoiding a
> huge unexpected sphere related shift in latitude.
I guess, the command I've suggested half a year ago in [1]:
$ gdalwarp -of HFA \
-s_srs '+proj=sinu +R=6371007.181 +nadgrids=@null +wktext' \
-t_srs TARGET-SRS \
'HDF4_EOS:EOS_GRID:"fpar8.hdf":MOD_Grid_MOD15A2:Fpar_1km' \
fpar8.hfa
could now be rewritten as:
-s_srs '+proj=sinu +R=6371007.181 +datum=WGS84' \
-t_srs TARGET-SRS \
fpar8.hfa
(i. e., the source projection is spherical, but the coordinates
used are the WGS84 ones)? If yes, that's good! May I suggest
updating [2] then as well?
Or do I miss something?
[1] http://trac.osgeo.org/gdal/ticket/1239
[2] http://proj.maptools.org/faq.html
More information about the Proj
