[Proj] Converting to SRS:4326
Bradley Mclain
bradleym06 at gmail.com
Mon Jul 16 22:00:18 PDT 2007
What I am trying to do is get the extent of my data which is on SRS:28355
and convert it too SRS:4326 so my map will display correctly.
I used the command
proj +proj=longlat +ellps=WGS84 +datum=WGS84 <geogdata.txt>results.txt
but it returned
+proj=latlong unsuitable for use with proj program
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070717/8919e536/attachment.html>
More information about the Proj
