[Proj] Converting to SRS:4326
Tue Jul 17 07:36:23 PDT 2007
Bradley Mclain wrote:
> What I am trying to do is get the extent of my data which is on
> SRS:28355 and convert it too SRS:4326 so my map will display correctly.
> I used the command
> proj +proj=longlat +ellps=WGS84 +datum=WGS84 <geogdata.txt >results.txt
> but it returned
> +proj=latlong unsuitable for use with proj program
Bradley,
With the proj command transformation is always implicitly between a
projected coordinate system and the corresponding geographic coordinate
system.
So you could do:
   proj -I +init=epsg:28355
to translate from EPSG:28355 coordinates to GDA_1994 coordinates (essentially
WGS84 as I understand it).  (Note the -I, to invert the normal lat/long to
projected transformation)
If you want to more explicitly control things, use cs2cs.
eg.
cs2cs +init=epsg:28355 +to +proj=latlong +datum=WGS84
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
